Good few pages to read.. Lol.
I had BC BRs on my 33GTR, they were nice but after a year or so started to creak a tiny bit at low speed.. only a tiny little bit nothing compared to when coilovers "knock"
My brothers got BC BRs on his 33GTST no complaints from him either for what it's worth
Lol no deal
Wanna get the gp pro gloves
Dainese gear too expensive rich kunt ^
Think the only difference between the plus and pro glove is the hard cover on the wrist strap...Dude at Peter Stevens told me not to bother with them over the Plus..
And the Pro is $250 like the Dainese Joust....
I said I want all that, not that I can afford it.
You guys too busy arguing over what the best /bikefashion is and not coming out on SAU rides :P
Just buy some gloves that fit, and come for happy fun mountain runs
Much much more compliant than SS.
In saying that, have never driven on brand new SS. Just second hand sets.
I would rate the BR's better than second hand Type Flex easy.
The BR, as I said, firm. But they don't bounce around or or skip off bumps.
Might be a goer then. That's my biggest issue with stiff coils...accelerating up a hill / around a corner and losing the rear end over a friggen bump :/
Mate in E36 M3 runs them as well. Drove the car a lot for a few year. No issues, they were actually much better than the stock BMW dampers.
I wonder how the BC V1 would compare to the BC BR, which are slightly cheaper and by description, more suited to street driving? Same spring rates though...
i dont watch ACA..
ill keep an eye out for him on ACA..
-_- *bored
I have a set of these lying about... Size large I think, got them but never used them.
Edited by JEPPE
too much black
i want these
no
i want the medics to be impressed as they collect my body parts
Nope, swapped the Merc with a mates Daytona for a few days. Sending it back tonight.
i see
Daytona sounded good from what I heard..
Also I liked your pace through the hills.. quick and fun but not silly (considering we don't know the turns) I always prefer following for some reason.. the DRZ kept up fine just some of the higher speed straights (120+) Adam was gone haha
Too bad we didn't get a good run down Burwood highway end
Rimon, my Fox gloves are awesome <3
cept green with rubber finger bits for 2 fingerin clutch / brake
    • Put a fuel pressure gauge on it. Replace the turbos. Probably completely separate issues.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
