Lol I think he was only ringing his bell after I gave him a friendly toot
And yeah evo was funny, off a roll I had nothing but really wanted to go him from the lights :P he must of turned off near where you did / before. Pretty sure I've met that dude once before and his evo has a bit of work done
He did seem pretty quick in the rolling, granted I wasn't in a very low gear, so could have toasted him even more :D
lol well im obviously brought up to have a lot more respect than normal rather than involve my self with desease spreading females who have no self respect. but as earlier said, each to their own :sweat:
lol man it's just girls touching lips, there's no cooties being spread. It's no doubt a cultural difference, but girls kissing for fun in western culture is pretty normal...particularly if they are drunk. Doesn't make them broad minded persons :)
Not all girls kiss in the open for attention, it is true a lot of them do though. That still doesn't make someone a $lut. Case in point, the above girls I'm willing to bet have slept with less guys than your girlfriends...
Yeh the ones that don't are genuinely lesbian
If they are strictly into girls yes...if not, then it's bi curious...and even then, if there's no sexual attraction, i.e. just for the fun of it...it's still heterosexual.
Don't know how you could look at one picture and say "would not marry" when you don't know absolutely everything your own partner could have done in the past, unless you've been with them since like age 12. Ignorance is bliss...
Not implying anything but jus sayin...assumptions are the mother of all f**k ups. I know these girls...one is still a virgin...and they are about as far as you get from slurry.
Don't know how you could look at one picture and say "would not marry" when you don't know asbsolutely everything your own partner could have done in the past, unless you've been with them since like age 12. Ignorance is bliss...
its not ignorance man. the type of person is usually dependant on the way they act in their comfortable state. if that making out with the same sex "For fun" the type of person, obviously, has no self respect for the image they are portraying of themselves.
if a females gonna kiss a female for fun, theres going to be other indecent shit she is going to do for "fun". fk marrying someone like that.
wanna have a happy life, dont have a f**ked up wife.
edit: would you kiss another male for fun?
dont say its different its the same shit. and if you think otherwise then you sir, are ignorant.
Edited by Sunkist
No self respect for their image? Image in who's eyes, yours? There's much worse things people do to their self image than kissing a chick.
Like I said, you don't know what your partner has or hasn't done in the past and no rule is ever a guarantor of a happy marriage. Divorce rate is that high these days, you got more to worry about than what single girls do for fun when they are young affecting your marriage. It's just fickle saying you wouldn't marry a girl because she's kissed a girl before. So many have done it before that you've probably been with one and wouldn't even know :)
Girls find being with guys fun too, doesn't mean they're gonna cheat on you when in a monogamous relationship. If I found kissing guys fun then I would, but I don't, so I don't do it. If a girl finds it fun, I couldn't give a shit, as long as she doesn't cheat on me with another guy or leave me cause she kissed a girl lol...not a single fk is given that day.
Got my mirrors today Adam so I don't have to completely turn around now - Also, our bikes are even.. to 50! :P
When are we hitting up the bike track again? And when are we wiring up our blackout switch? :D
Also.. on the topic of $luts, how many sexual partners would make a average 25 year old girl a $lut?
3-5
5-7
7-10
10-15
15+ (obviously a broad minded person?)
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
