I've yet to see one on the road. Might wait for the STI tuned BRZ coming out next year, has 50 more hp (still N/A.) I've got a bit of time to decide seeing as they sold out the entire years allocation in 3 hours today.
still worth throwing in power fc and getting a tune if im not changing turbos for a while?
Whack it in and get it tuned then enjoy 240-260rwkw, Harsh did 275rwkw with pods, exhaust and boost restrictor removed on stock turbos.
Is the clutch still holding up ok?
Dooo eett!!
Last time Grant let me drive it, it needed more powah!
Yep, it does need more power!
Oh herro Grant. When you back from overseas?
Gonna step back in a GTR or are you over it now :)
lol nope happy with my motard - 1 less rego and insurance to pay off + need the cashola
I never rode that bike anyway
You would have if it did 0-100 in 2.9 seconds :P
Hello Mr Accountant, might be back in 2-3 weeks time, gotta explore bit of europe for 2nd time before potentially heading back this soon.
Might get another GTR and not growing up at all, if I'm back, I gotta get myself a job first though.
Man of Birds you still selling Syn-X 6000? If so how much. PM me if you want
Cut off distributorship with GW, sorry mayne. Can probably get it from a GW retailer cheaper than you could have through me anyway.
surprisingly it is! it slips ever so slightly..
i cant say i drive it hard though, i baby it around nearly everywhere, i was actually looking at clutches last night, like 800$ cheaper to get coppermix comp straight from RHD than anywhere here, which is a pretty big mark-up..
also i may hold up on the pfc for a few months until everything else is done then take it to trent for a tune.
also yes come back get another gtr
Either get a Nismo Copper Mix or an Exedy Heavy Duty Clutch.
Nismo clutches are made by Exedy.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
