still got your GTT stockies?
mind if i borrow them for a bit till my BBS' arrive?
thanks <3
yes you can, but the tyres are quite worn on those wheels, in fact, quite worn is an understatement.
I hope you are not planning on putting r34 gtt stockies on the r32....they will not clear the fronts...
Douchebag
lol. never knew that.
the hella ones? havnt gotten them yet.
they are the ones i bought. the ones in the car are stock and one of them sounds like there stones in it.
ah okay, was confused thought you meant the hella ones weren't loud :D
job interview tomorrow at ADT, wish me luck boys <3
good luck man :D
anyone know if there are any places which sell defi gauges in Melbourne? or at worst in Aus?
trying to grab an oil press gauge (no overnight parts from japan yo)
good luck man :D
cheers.. going crazy jobless atm!
My cousin owns a online parts store i'll see if he can get them.. I know there was talk of him beginning to stock them but thought most people were too cheap to buy them :P
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
