for the past year or so my eyes have been hurting heaps.
last 3 weeks its gotten to the point where i sometimes wear sunnies in the office.
my eyes dont like the light.
going docs tonight. better not be going blind lol
kgo sau doctors.
Aaron was doing 1:38's sliding around at corner 4 and last corner before the straights
lol yeh when i was sliding around i was doing 1.38s and they werent the only corners.. i was doing where alvin was aswell
Edited by Sunkist
Chris with gtrrkt was doing 135 taking it really easy in the corners and flooring it in both of the straights.
Yeah I was just rolling through corners. Would love to see what the car could do flat out around Sandown.
Are you good at your job? Is there a high request for your role? Yes-no
Give me a pay rise dream boats or I'm out
Say you're on 'X' currently, and looking to further your career now looking for a little bit more 'Y' give them the vibe you're worth the extra and influence them / sell yourself
That's cuz Aaron is a sick kent
kgo sau doctors.
Pretty sure your turning into a vampire
Come to Sandown again on the 11th?
I was a flaggy when I needed some cash at a sandown day once was pretty easy 100 bucks lol sitting in a seat watching lexus / 35 GTRs etc i might come down and watch ya Toby
Martin I heard you were training my brother a bit down at PI :P
He blew a gasket I think.. silly unreliable RB25 :P
Haha I got that job now but now its 150. on call baby. free lunch too!!
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
