Nah just doing something for my parents... Was supposed to be a straight forward job, but whoever wired the joint up 25 years ago was a f**king mong, so it turned into a kunt of a job and took way longer than it would have...Got it done in the end though, and at least future jobs should be easier so it was good to start with a bad/hard one in a way..
Definitely not enough room to stand/walk or even crouch...Was crawling around on my stomach trying to stay on the joists...Almost went through the plaster lol
Good fun sabre sawing lying across a few joists, holding myself up with one foot hooking onto a rafter at full stretch lol
Gotta do the same thing in the other bathroom still, just hoping they didn't take the retard route when wiring that one up like the one I did today lol
lol sounds familiar, resting your stomach/knees on the joists isn't very comfy
hate that filthy/dusty insulation they used in older houses
just make sure you're not sore from training the day before otherwise it'll be 10 times more of a mission lol
my foot's gone through plaster couple times got lucky both times it was on top of bulkheads...
we usually try to avoid working on old houses unless it's really worth doing ($$$) or it's for a relative/friend etc
Yeah f**k doing this job if it wasn't for my parents or big $. I don't mind coz I'm getting some domestic experience which I can't get at work, so I'll do any domestic work I can...
Left forearm is f**ked like I ran it along a cheese grater...f**kin sabre saw was shaking the f**k out of me because of the position I had to be in to make the cut, and being hardwood I was cutting for a fkin long time...
And yeah that old insulation is f**ked, would be a lot easier if it was the new shit (which was on top of the old shit lol) as you can just move it around easily..
Definitely need some knee pads for the next one though
haha moving tools with you up there makes it more fun...
careful when lifting your head up alot of houses old or new have nails/screws sticking out of the trusses. dude that used to work with us had half a nail go through his head once. i almost had my fkn eye taken out too
new insulation itchy shit but yea least you can move it
ah yeah, didn't even think of that but did smack my head on a truss lol
Pulled a muscle in my neck/trap on Friday at gym, so was thinking it's gonna be even more of a bitch maneuvering around up there, but I think it loosened it up lol
lol lucky
usually get a sore back afterwards :/
mmmm
http://www.gumtree.com.au/s-ad/appin/motorcycles/triumph-daytona-675/1004413072
guy asks a question about auto -> manual on p's
so a moderator puts in his advice and is completely wrong.
so i input the correct advice. guy says thank you.
moderator has a mini tantrum and locks the thread.
god i love ns lol
http://www.nissansil...howtopic=521776
Edited by Sunkist
JDMST? Pfft...all about the Tony and Birds cruises these days
Will have to organise another one some time down the track
do an SAU wastelander lunch soon.
Your house or Alvin's?
Was good seeing you again today! Hope you don't tell the ato about me today hahaha
Cheers for the sausage sizzle and drink!
I'm not very good with faces so always need a reminder :/
awesome guy
Love you too brah
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
