Impulsive overspending?
Just need to wait for those in brissie to wire me my monehh
you in the white powder business too?
do HotPot. defnitely good in winter!
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
Edited by Sunkist
Dropped car off in the morning to get some tint done.
Was all excite but just got a call saying due to demisters extending too much or something the tint won't stick to the rear window so it can't be tinted? :(. Said he hadn't seen this before :/. Taken pics so I can see when I go and pick her up, but yeah :/
Anyone else encountered this before?
Aaron would need to take off his front bar to get up alvins driveway. Think toby will be find as his is stock height?
I think my car is higher than stock height LOL
Could just do my house, 1/2 way between Aaron's and Alvin's house :P
Not sure, didn't have that problem when I got mine done...
lol then why does the guy want to lower his car? and lol you'd be suprised, my car actually does alright on most shitty driveways.
even better, albino can cook
Saturday night 11 August, I might be doing a small gathering for Bday bbq and drinks.
Could also do a 'smallish' wastelanders food and drinks together on that night as well if there is a few up to it? And if Alvin wants to whip out some delicious food :P I'll pay for the food brah
your going to be wrecked that day from sandown bro
Yeah same day. I was going to do something later for my bday anyway.
Who knows might need a drink to drown my sorrows if something happens that day lol
Lol nothing's gonna happen dude. I might not join in on sandown. Allignment needs a doing and they said I'll need to flare my guards some more(traction tyres) with that and a retune plus cams etcs it's going to be an expensive exercise to only get kicked off for noise.. But will see what happens. Il definitely come watch
wasteland maf**kers, sat night, sept 1st, lagerfields at crown. going to be celebrating my birthday and shit and want you dream boats to be in on the shenanigans. ill have a penthouse booked so...... theres a place to KTFB
You bringing hookers to the penthouse?
    • If you mean the alarm immobiliser; theyre internal to the alarm itself which makes that difficult; I couldnt even see where he put it; its not in the same place as last time; but with all black wiring it might be very challenging to trace  I had someone turn the key for me as I know it only primes for a couple of seconds As my post above; I am getting no voltage to the pump at all; but I am testing continuity of the power line (SB) from the pump plug to the relay fine. As well as the negative from the pump plug to a 12V constant.    Yeah; he blammed the no start on a bad battery; said I needed to get a new battery and it'll start. Turns out the battery drained because the tail lights had been on for half the day during the install (the rubber cushion on the brake switch gave out while he was testing it as I have a picture of the car from that morning with the tail lights off..i've replaced that). The battery was turning over the engine just fine for a long time; but got low since lights were draining it so it was too low to test a start after he finished. I bought a new one on his advice...$250 wasted. My original battery charged up just fine and is healthy.    It was running perfectly fine when I messed up the old alarm (programmed out the remotes). He couldnt start it after removing the old alarm; my assumption is that when he unhooked it; he didnt bridge the circuit back when trying to start it. Its always been perfectly fine. The ECU swap and pump were 2 years ago. It's never missed a beat in that time.
    • This is a big issue for me without the diff. I just have zero drive from the passenger side when drivers side has no traction. Bec's parents place has a crazy steep driveway with odd camber and I have never been able to get up. My bro-in-law's 130i with an (unknown brand) LSD gets up fine as does their dad's Hiace. My car stays at the bottom. We have other odd camber roads around here as we're elevated a bit and if it's raining I can get totally stuck around some hairpins.
    • Yeah, I am super excited for this.
    • Was the car running before he touched the car?
