Not sure, didn't have that problem when I got mine done...
Never saw this problem coming or myself. Googling I have found it is possibly possible that there is a 'silicon coating' and etc. I don't even know. I see on some tint forums this problem too maybe, people suggesting 00 steel wool or something. Ahhh Ceebs, why couldn't it just be tinted 2ez xD.
Saturday night 11 August, I might be doing a small gathering for Bday bbq and drinks.
Could also do a 'smallish' wastelanders food and drinks together on that night as well if there is a few up to it? And if Alvin wants to whip out some delicious food :P I'll pay for the food brah
i should be able to make it 11th.
i have 1.4kg of wagyu for slicing into hotpot thickness.
i can probably do one serve of singapore style chilli crab, of course, using mud crabs.
could also do some wagyu tataki. or something like that. can't think of anything else though, satay is too much work and requires a bbq grill. full 24 hours marination and shit.
Ease up lads
Is it a full month behind or they are just overdue on the pay date?
We reminder SMS at 1 day late letter at 3 SMS at 5 and so on
Can i interest you in our property management capabilities?
yeah full month, got paid for 2 weeks today but they were originally 6 weeks behind
went in and told them about it, they going to follow it up now anyway
In any case though Barry Plant are shit dream boats, instead of being paid monthly like requested its fortnightly, then every three weeks, then monthly, then fortnightly again
it's all over the shop :S
i prefer the Singaporean black pepper crab, was spicier and tasted better. Could have been where I went (don;t ask cause I don't remember :P)
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around without a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
    • Yep, this bit another local owner. I caught it before putting the transmission back into the car, what I noticed was the pressure plate fingers weren't flat and even. It's more obvious with the pull style clutch because the throwout bearing ring was visibly not flat once everything is put together. Nismo should really update their instructions to call out this specific detail. I'm not even sure the clutch as-shipped orients everything properly.
