Ease up lads
Is it a full month behind or they are just overdue on the pay date?
We reminder SMS at 1 day late letter at 3 SMS at 5 and so on
Can i interest you in our property management capabilities?
Lol my real estate agent forgot to pay for insurance after I requested. Only realised 1yr later that there was no deduction...
i should be able to make it 11th.
i have 1.4kg of wagyu for slicing into hotpot thickness.
i can probably do one serve of singapore style chilli crab, of course, using mud crabs.
could also do some wagyu tataki. or something like that. can't think of anything else though, satay is too much work and requires a bbq grill. full 24 hours marination and shit.
Happy to host it if there is enough interest
Say 5-8 wastelanders brahs should be sufficient
You know what to get.
Lucky your mate's bet got refunded.
what a r1? :P
yeah I know right haha he said good that he lost or else he would of been thinking about 2.5k all day
I'm still a big motard fan, just like the fact you can go offroad and if you drop it practising wheelies not really a big deal compared to a 1000, also just rare you never see them around and people go wtf? lol
R1s are the sex still though.
hilux has arrived!
went checked it out today still needs to get all the extras fitted before we can pick it up hopefull by the end of the week
saw one of them 86 things at the dealership gotta admit it looked pretty good in person and in black. not impressed with the interior/dash though
that one's a lot of work involved. lol. but i could do a serve of that too.
haha it's ironic though, because you look at the two and you would think the chili crab (with all its sauce etc) would be harder to make :P
Guys,
I've got a bit of a horizontal crack on my tailight, anyone know what i can use to not let water get inside?
No sign of water inside but just making sure it doesn't get in.... was thinking some kind of silicon.
Guys,
silicone it from the inside if you can! will never see it.
or use some of that powder activate supa glue and wet sand /plastice polish till smooth.
Cheers Aaron! Remind me to give you a free sausage next time! :-D
hmmm... powder activate super glue.
Edited by Down_Shift
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
    • You think its the AFM? I know its a common issues on R32s. I find it coincidental how this issue raised right after cleaning the fuel system. As everything except the fuel system was fine before. I tried running it with the IACV unplugged but did not notice a difference and still stalled. However, the RPM gauge is not in the cluster right now, so I will need to connect the laptop again and use Nistune to check the RPM. I will check this weekend.
