Ease up lads
Is it a full month behind or they are just overdue on the pay date?
We reminder SMS at 1 day late letter at 3 SMS at 5 and so on
Can i interest you in our property management capabilities?
Lol my real estate agent forgot to pay for insurance after I requested. Only realised 1yr later that there was no deduction...
i should be able to make it 11th.
i have 1.4kg of wagyu for slicing into hotpot thickness.
i can probably do one serve of singapore style chilli crab, of course, using mud crabs.
could also do some wagyu tataki. or something like that. can't think of anything else though, satay is too much work and requires a bbq grill. full 24 hours marination and shit.
Happy to host it if there is enough interest
Say 5-8 wastelanders brahs should be sufficient
You know what to get.
Lucky your mate's bet got refunded.
what a r1? :P
yeah I know right haha he said good that he lost or else he would of been thinking about 2.5k all day
I'm still a big motard fan, just like the fact you can go offroad and if you drop it practising wheelies not really a big deal compared to a 1000, also just rare you never see them around and people go wtf? lol
R1s are the sex still though.
hilux has arrived!
went checked it out today still needs to get all the extras fitted before we can pick it up hopefull by the end of the week
saw one of them 86 things at the dealership gotta admit it looked pretty good in person and in black. not impressed with the interior/dash though
that one's a lot of work involved. lol. but i could do a serve of that too.
haha it's ironic though, because you look at the two and you would think the chili crab (with all its sauce etc) would be harder to make :P
Guys,
I've got a bit of a horizontal crack on my tailight, anyone know what i can use to not let water get inside?
No sign of water inside but just making sure it doesn't get in.... was thinking some kind of silicon.
Guys,
silicone it from the inside if you can! will never see it.
or use some of that powder activate supa glue and wet sand /plastice polish till smooth.
Cheers Aaron! Remind me to give you a free sausage next time! :-D
hmmm... powder activate super glue.
Edited by Down_Shift
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
