I wanna see a photo of her pulling the trigger, now that'd be some trickery!
The thought that she pulled the gun away to crop through the 10 photos she likely took and then uploaded one of them kind of ruins it.
Congrats Dyl, fine choice. And with summer on it's way :thumbsup:
Thanks, got a new roof installed on it recently so I'm ready for winter to come at me bro.
I'm not a huge fan of the convertible thing, I'd feel a bit girly driving around with the roof down alone or with another guy in the car... no homo. Can only have the roof down if the girlfriend is in the car.
Nah you'll love it...come summer with the top down, you can't beat a convertible. Do agree about two guys though...in an S2000 that's a bit hairdresser and fashion designer lol. Can always get one of the Mugen or Spoon hard tops, they look pretty cool.
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
