Well so far being a member for a month or two and been to the last 2 months garage cafe meets, SAU vic execs are doing a great job. Not sure how the members section side of things are as i don't have access yet....
Just curious, who is this Ash guy? I still want my members access lol
Member section is dead. Nothing in there. All chat happens in this thread. Nothing to lose sleep over.
lol, i didn't mean it in a way to imply that you said anything negative about the vic commitee. I clearly understood what you were saying, chill brah! :spank:
Just wanted to voice my opinion on my experience so far with the vic commitee. :nyaanyaa:
Deep down Aaron is a big softie
Don't take to heart much what he says :P
lol f**k Precinct, line all the way to Punt Rd after 9pm and idiot bouncers who let in people with shitty runners on but not Timberlands/Colorados. Take your mates up Swan St for better pubs/hangouts.
yeah well I looked at all the modern cars.
86
GTI
focus XR6
none of them worked for me
so I thought I might spend a little less and get a fun car
so looking at S15 or 34 GTT
but damn, how cheap have 33R's got, so i'm thinking for a low KM daily why the F not have something fun!
so atm it a 33R or a evo6 TME
I had exactly the same thoughts as you. I was tossing up between the 86/BRZ and the GTI. But fairly certain I'll go for an 86/BRZ later next year. An R34 GT-T or S15 crossed my mind but they're a bit old and the fuel consumption of the R34 would be too crap for a daily again.
I'm not so worried wabout fuel usage as It will get low km
We will lease a nice daily something Like a tigran or similar that will be the main car and do most of the km. then a 2nd car for me for when I go in the office or run errands. so will do 3-4000 km a year.
So might as well have some fun.
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
