You sure they're not CBRs they do look similar...
Saw an undercover motorbike pulling someone over :/ wasn't aware of their existence....
I saw that too the other day.
but they're bikes looks somewhat "Travel" like, right?
Just spent another 2.5 hours in Rimon's territory aka roof space. I love that shit now.
Lol did some roof work myself too today was in a new house though and very roomy :P
I see ALOT of spider webs in roofs even in new houses but never see the actual spider. 9/10 it's them harmless long legged spiders so meh
Come past mine afterwards, I'll be home :)
okay darling, spoke to the guy on the phone and agreed / he advised not to go for a balls to the wall tune and turning the wick all the way up hopefully a mild 350ish rwkw on his dyno (anything over i'll take as a bonus), still huge power some tuners go really aggressive with hem though but I won't just yet while it's still new..
lol the no lag thing is weird, compared to a laggy turbo car (ie my old GTR) that sudden rush of power I do miss.. but pulling skids in any gear is also fun :P and don't need to rev the crap out of it to go half quick. A v8 twin turbo would be my preferred balance :D
Aaron, you can never have enough power thought you knew this? :P
nah definitely 675's, they've got the badging on the fairings...
Yeah heaps of that around up there, but didn't see anything moving.. I've gotta do an exhaust fan or 2 at my place still....More room up there from what I've seen, but also had a rodent problem a while ago so not looking forward to getting up there...Especially when one of the fans needs to be installed about 2 meters from where I used to hear them the most...Should be interesting, hopefully they've all died and decomposed by now, and hopefully the smell is gone. Haven't heard them for ages so I'm confident they're all dead/moved out, but still likely to find some remains...
Hope you got some new tyres lined up...
Don't need new tyres when your fat ass weighs 1800kg.
Just pumped mine up...265/35 @ 33psi lol. 40psi makes such a huge difference to the comfort and handling.
Bunnings is the worst store to go and buy something specific; end up there for 2 hours browsing at other shit.
to the 86 dirvers, is the "awesome driving experience" simply because the thing is so underpowered that you just leave your foot on the floor and turn the wheel?
srs question...
my ksev was like that and to have fun you had to treat the clutch like rodney king
lol thats probably it. well balanced, low centre of gravity, rwd & foot flat in the corner. Probably feels a lot safer than a 350kw ford falcon doing the same thing haha
lol
where you putting em in bathroom/toilet? just run the wire from the light with a tongue/snake and save yourself getting up there
unless you want your lights/fans controlled seperately then different story...
lol
Yeah bathrooms, seperate switches for heat lamps/light/fan all in the one unit...
Don't know how you'd get a tongue from the light to the switch without getting up there though? please explain.
Whatever you're about to explain might work on a house that wasn't wired up by f**king retards, which this place was...Made a simple job a headf**k and a half
Don't be hating on the falcon :(, 350kw + pedders = leave a 86 for dead through the hills :P not as bad as people think in the dry at least
Put my engine in the 86!
    • Onto the rear lower shock mount. It's worth starting with a decent degrease to remove 10+ years of road grime, and perhaps also spray a penetrating oil on the shock lower nut. Don't forget to include the shock wiring and plug in the clean.... Deal with the wiring first; you need to release 2 clips where the wiring goes into the bracket (use long nose pliers behind the bracket to compress the clip so you can reuse it), and the rubber mount slides out, then release the plug.  I found it very hard to unplug, from underneath you can compress the tab with a screwdriver or similar, and gently but firmly pull the plug out of the socket (regular pliers may help but don't put too much pressure on the plastic. The lower mount is straightforward, 17mm nut and you can pull the shock out. As I wasn't putting a standard shock back in, I gave the car side wiring socket a generous gob of dialectric grease to keep crap out in the future. Putting the new shock in is straightforward, feed it into at least 1 of the bolt holes at the top and reach around to put a nut on it to hold it up. Then put on the other 2 top nuts loosely and put the shock onto the lower mounting bolt (you may need to lift the hub a little if the new shock is shorter). Tighten the lower nut and 3 upper nuts and you are done.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
    • Yes. Autos typically work from the speed sensor on the pinion shaft of the diff. I also think that even if you have a proper speed sensor for the bog manual in the manual box, that the signal it outputs is not compatible with the auto dash anyway. You should consult that manual (the book, not the gearbox).
