tune only brahs - mirin (made the power with stock timing)
So damn linear lol. Look how flat that farkin torque curve is.
In other news, Soundwave 2013 line up is looking pretty farkin good. In on that shit.
da fuq at Shannons insurance?
They won't do quote on phone anymore, what?!
Just cars want $800+ more per year for basically same car - what?!
What did they do while I was abroad?
lol
Lol what a cock, can afford a 458 but not a ticket? They shoulda beat the shit out his ass
Waiting for the car to get tuned at Epping plaza, what do? : /
Made 253 on this dyno shows chasers was a bit happy at Sau dyno day?
Shoulda visited me at work
Wow big difference.
Do you know any of the rpm points?
Come enter Sandown! Make use of the power brah
He showed me at the place but on the print out nope, rev limit is like ~6500
Nah not going to track the car this early anyway, pretty sure I'll need a set of brembos now :P
Thats boost! but yeah torque and power delivery nice and smooth
Would prob make 400 on chasers dyno :P - hopefully the roads dry up a bit tonight
Why the f**k am I getting ridicously high insurance premuims for Skylines from both Shannons and Just Cars?
They both wanted $2400 a year for 'highly modified' cars...
So I've got to come up with a car that is fun, fun, reasonably priced to insure, and fun.... Suggestions anyone?
370rwkw, will be very interesting to see what it does.
You'll like the trophy classes as well... Making sure the non-skyline people are not forgotten :D
hahaha.. not sure how hard I would go.. don't want my boat flipping at 300km/h :P
I was told to never track something you couldn't afford if you crashed.. and can't really afford to crash it right now with no job especially..! Hopefully have a new job by then though.
I'll definitely be up for the 1/4 mile and most likely give the 1000m a few cracks
Should be a good weekend if it's even half as good as last years :D
Edit: just saw it's actually 800m how much faster trap speed would that be than 1/4 you reckon?
How are you going to crash on the airport? :)
800M will probably see ~20km/h less than the 1000M, not 100% sure but given by 800M people are well over 200km/h, moving that fast the extra 200M you wouldn't pack on another 50km/h or anything that's for sure
cool cool, it was more so the surface that I saw on some evo nats youtube clips I was worried about, seemed VERY loose
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
