http://www.carsales....998&sort=~Price
R34 motor right? Doesn't seem to mentioned in comments, unless of course owner stripped paint off plenum and painted rocker cover as mock up.
Could this be a dodgy car?
Reason I ask is because I looked up the VIN on RAWS website and there are no records of it on there.
However the VIN does show up on vic roads VRE.
Makes me wonder what's happened there.
Edited by RB2600
Just a minor price difference....
Bought the latest Motor Mag Bang for your buck. I always find it a good comparo
Toyota 86 - 10th
0-100: 6.96
400m: 14.89
Wakefield lap time: 1:13.49
Subaru Brz - 8th
0-100: 6.93
400m: 14.93
Wakefield lap time: 1:13.79
needs more turbro!
In other news, Soundwave 2013 line up is looking pretty farkin good. In on that shit.
It's actually kinda shit compared to this years lineup.
But I will see Madball / Dragon Force / Blink 182 at the Sidewaves.
Don't think I'd ever get a Ford... your attempts to convince me otherwise are noble though Leigh
Haha fair enough :P not like I'm a die hard fan or anything i've still owned more imports than anything else just sayin' there's other things out there :P
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
