according to the text i just recieved i've won 990,000 pounds in nokia/freelotto :huh:
fezas for all
Quick give them your credit card details and expiry and ccv number on the back so they can send it to you
0:00 - 1:05 best thing i've heard in ages
should sack all current rappers and just make remixes of old school tracks...
Veli - the warning shot. winner
What happened to Justin911? He had facebook but prob deleted me :(
Don't think he ever really used it
Sneak preview for Rim...polished bike today. Wax/sealant goes on tomorrow for shine/protection. The polish wasn't a harsh one, so the deeper scratches are still there, but I'm pretty happy with how it came up. Now strong aware of why people hate owning black vehicles.
Before
After
Top half of windscreen unpolished, bottom half polished
Now if the weather would clear up so I can ride the farkin thing!
oh also a note, was on the way home from a work meeting earlier, booze/drug bust on bwd hwy just before mtn hwy... one of those ones where they block off both the left and right lane; and force you into the centre one. so slight delays there lol. i got waved through though this time :D.
+1 :(
Looks like it's come up pretty good brah. Is it less work to polish bike since less area?
Yeah less physical work, bit trickier though...jagged fairings and tight nooks means you gotta take your time and do it by hand instead of machine. I'm pretty obsessive too; if you just wanted to polish the main/obvious fairings, you could do it in under an hour.
That was just the tail lights surrounds...farkin mismatched to the body colour. Seems to be common with 34s. Came up a little better after the polish, still off though. Your whole car needs a respray lol.
i hate owning black vehicles.
but would own another black soarer. am srs.
lol. its a daily, its gonna get dinged up. not too fussed with the different colored panels tbh
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
    • Wouldn’t touch par if they gave it to me. You need to ask how much power you’re looking to make and then add about 50% to it because that’s what you’ll end up making  The factory box says no more at about 350kw or so, the upgraded synchro boxes won’t handle much over 500kw for long and at that point you’re looking at an auto or dog engagement manual,  once you’ve gone dog engagement you may as well go sequential, they cost a little bit more but it’s worth it  also while you’re at it you should upgrade the transfer case with 10 friction plates
