according to the text i just recieved i've won 990,000 pounds in nokia/freelotto :huh:
fezas for all
Quick give them your credit card details and expiry and ccv number on the back so they can send it to you
0:00 - 1:05 best thing i've heard in ages
should sack all current rappers and just make remixes of old school tracks...
Veli - the warning shot. winner
What happened to Justin911? He had facebook but prob deleted me :(
Don't think he ever really used it
Sneak preview for Rim...polished bike today. Wax/sealant goes on tomorrow for shine/protection. The polish wasn't a harsh one, so the deeper scratches are still there, but I'm pretty happy with how it came up. Now strong aware of why people hate owning black vehicles.
Before
After
Top half of windscreen unpolished, bottom half polished
Now if the weather would clear up so I can ride the farkin thing!
oh also a note, was on the way home from a work meeting earlier, booze/drug bust on bwd hwy just before mtn hwy... one of those ones where they block off both the left and right lane; and force you into the centre one. so slight delays there lol. i got waved through though this time :D.
+1 :(
Looks like it's come up pretty good brah. Is it less work to polish bike since less area?
Yeah less physical work, bit trickier though...jagged fairings and tight nooks means you gotta take your time and do it by hand instead of machine. I'm pretty obsessive too; if you just wanted to polish the main/obvious fairings, you could do it in under an hour.
That was just the tail lights surrounds...farkin mismatched to the body colour. Seems to be common with 34s. Came up a little better after the polish, still off though. Your whole car needs a respray lol.
i hate owning black vehicles.
but would own another black soarer. am srs.
lol. its a daily, its gonna get dinged up. not too fussed with the different colored panels tbh
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
