Nah that link i posted said at the wheels
It is powered by the locally built all-alloy ‘Miami’ Boss 335 5.0-litre supercharged V8 petrol engine introduced two years ago, which continues to deliver 335kW of power and 570Nm of torque to the rear wheels via a six-speed manual or six-speed ZF automatic gearbox.
sif they will EVER quote power at the wheels... that doesn't get people buying cars
not as bad as that topgear episode where they threw cars on dyno's and then went on abuot how much power they had lost from the factory as a result of age as opposed to engin vs wheel hp
THAT was appauling
birds cruise down to garage cafe?
can pick you up this time if you like baby <3
Nohomo.
Yeah you can be my wheelman tonight...
nohomo
Shame it's started raining, won't get to use all your power :/
THAT was appauling
actually that was a dyno that is meant to give FlyWKW
so it does a normal dyno run, then you leave in neutral or something and it can tell from the drag how much power is lost though the drive train thus giving a FW rating.
no idea how it works but yeah...those crazy germans
really... that's cool as!
paint it BT1 yellow
it already is yellow
I started a thread for motorbike detailing, my shit is in there
http://www.skylinesa...ycle-detailing/
I reckon a light polish would do you good, but maybe go over it with prepsol first...it's good at removing sticker residue if that's what's left behind. Could also be the rest of the paint that's faded whilst stickers have preserved the paint beneath.
yes that but its not faded just not as clean somehow. i'll give polish a go
i'll check your thread kthx
Found some helmets that you bikelinesaustralia could use
would definately wear a predator helmet and wouldn't give a fck what people thought of it
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
