making decent coffee isn't hard to learn :P
my ex use to work at a coffee shop, was good!
Tony mirin my lane changes last night lol - birds it's dry today! did a hugggge 2nd gear power skid before down my cousins private street ofcourse loving this whole power thing car felt slow as f**k before
Alvin - whens next wagyu / hotpot / duck night?
Hrmmm didn't notice anything out of the ordinary lol
Just alot of slow drivers on the road...
ah nevermind then lol
Busy tonight Leigh? Pm me your number brah
Can't tomorrow Mohsen, I'm an important man
aight ill pm ya, what you got planned? nohomo
P.a?
R&d is tech role unfortunately. Food science etc.
I believe the marketing, sales, engineering and it roles are filled.
Any grad positions available for mechanical engineering Patrick?
any grad positions available for chemical engineer?
I can also make a decent coffee.
haha, nah sorry guys, no engineering grad jobs going. Theyve all been filled.
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
