Yeah, lots of good reviews. 1.2k, can't complain. If i bought the specific ones for my civic (fork), it'd be 1.1k. But I'm running integra type r stuffs underneaths, so have to pay for that type R tax :[
That's the price you pay Honda fanboi lol
All coilovers look the same in the end anyway :P
Must admit loving my pedders coilovers so far
What do pedders charge for coils roughly?
Seems legit
1750, but fords have separate springs from shock on rear so dunno if that makes it cost more or what ever
pretty funny how my stock springs only saw like ~2000kms lol but this completely transformed the car to something more sporty feeling with a luxury side as well way more difference compared to getting them in my GTR
Just want an intercooler, exhaust, brembos and wider rims now! modding bug never stops..
like this (to make sense of it) not sure what brand this is though:
Nah price won't affect the rear shocks being seperate, vdubs have seperate rears and price is same as normal coils
also, LOL
HAHAHA
Did you pop your motor? What's planned for it?
Yeah, from what Racepace figured out, piston 5 had a cracked head, making a loud knocking noise and loss of compression.
Wanted a standard rebuild, but Racepace justified how a forged will benefit in the long run and I totally understand.
spoke to jamie at garage cafe one of his pistons was knocking or something, he's getting it rebuilt (forgies) with -5s or similar
Yep, but using my stock (rebuilt steel internal) turbos for now.
Till I speak further to Chris about what he thinks.
From memory, he prefers -7's.
Jaime did I see u at wtac?
Hey Alex!
Nah, don't think so man, I didn't go to WTAC.
How was it? I saw some pics and they look quite good.
Think he wanted -9's. Were trying to convince him to go -5's to make use of his built engine, we'll see if he will succumb to the powah!
But nah -9's great for the street!
:D
If I had a HKS V-Cam or a stroked 2.8lt RB, then -5's would be an option.
But yes, for street use, -7's or -9's.
    • Power steering is probably because someone has nuked the HICAS CU and you no longer have the variable power asist doing what it is supposed to. How much boost are you running? You are aware that any more than 10 psi on the stock ECU is just asking for it to go to full R&R (that's Rich & Retard, which is effectively Retarded and Retarded!) which kills all the power. Depending on the exact conditions, it can just be runnign on the fat and stupid end of the maps, then the conditions change, you make a little more boost and the ECU goes into panic.
    • @BuiltNotBought Just as GTSboy said.   If you want driveabilty and more low down torque..keep the stock runners. They are VERY good from a factory. I have them too on my RB25DET NEO and as a GTSboy i have fmic but with stock piping route(i have Blitz intercooler) Iam making around 320 BHP and the car pulls "hard" from like 2,5k all the way to 7k. I have it dyno tuned to mimic N/A power curve and making little less max torque due to the smallbox tranny. But driveability is very great. I had 350Nm below 3k so car feels very quick.   EDIT:  Not my channel but i saw this and i know that is what i want (and i have exactly this)
    • Looking to sort out a couple of issues on my skyline  It recently was rebuilt, however rebuilder long story short did not give two flying effs about the work he did. So moving forward it's running but I have two persistent issues 1) it has a misfire / lag type of issue (was at higher RPMs but I had a dead piggy back ecu removed which improved it) now it's not as bad but still does it at random, I thought it may have been a boost issue I'm running an older turbosmart dual stage controller, turbosmart told me to try running off gate pressure however it still has a lag at random times. It has New MAF, maf plug, coil packs, sparks, CP harness.. injectors tested and cleaned. Factory ECU. 2) Power steering issue. It is tight as anything. Flushed power steering, rebuilt my pump because the bearing was shot. Flushed again still tight (mainly when parking and going slow into my driveway etc)  No kinks in hard lines, replaced the lines I could see had cracks. Still tough to steer.  I was told to shim a coin and place into the solenoid plug? Is there anything else. My steering angle sensor also has a issue. It's a used one I replaced, does it need to be calibrated? I feel like I've tried everything and this car is my voodoo doll.
    • Holy shit... wow!!! I totally missed this
    • One main filter. Each tank has a prefilter to keep rocks and small children out, then the big main filter that also does water separation. Clogged the first one so bad it was like a rev limiter at 3200rpm. Literally just like dropping the throttle off and maintaining rpm!
