Billy has an 86 he also teaches.
Nick get on sbsone they have popasia on! You'd love it. Not sure if its just a Qld thing
Haha yeah it's on Saturdays on sbs
used to always watch it, but now I'm either busy or sleep through it :P
LOL
Yellow "Mach 1" fast back stang in yellow came in today. Freshly imported, not rego'd yet, lol. Anything specials?
there a mint muscle car and surprisingly look pretty good in yellow
I'll let you have that one, only cause I know you get infinitely more sick than me :ninja:
I give you that one :( But far queue, I am well right this second. I maybe wasn't two hours ago but that's besides the point.
At least we're alive lol, plenty of people don't have that :)
