I had a cheap set, after a few jobs and breaking/bending things, threw whole lot out.
kingchrome/sidchrome now, with new bits prob going to be snap-on
My old mans Sidchrome ones lasted 30-40 years of heavy usage on the farm b4 some junky stole them.
Ash when nats entry...
I'm in Syd this w/e to sort it out - im gunning next week
ASH, send me the shit so i can start spamming meets lol
Yeah working on that man, gotta wait probably 2 weeks before that stuff is ready and ill come drop it off :)
payday next week so sweet...
being thoughtless to the other clubs but with us running deca next week think you can make it the following week so that the sort of ppl that will enter will be near a computer and not running an event ;)
Wasn't for you, don't think yourself that important that I'd even waste 5 seconds :thumbsup:
I'll be @ DECA so it won't be going live whilst I'm there :)
    • Bit difficult to follow. Have a look below and see what the standard R32 layout was like. Note there was a restrictor in place immediately before "turbocharged pressure control solenoid" that, if removed, magically got you 1 bar boost.
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
    • Carrying out some engine due diligence before my first drive in a 260RS that has been in storage for 10+ years, and found two lines that are susposed to be plumbed into the boost control solenoid. One of the lines (the wastegate boost supply line) to actuate the gates, had a bolt in one end blocking it. The other line (main boost signal line) from the very rear of the intake manifold (RB26DETT) and runs up to the boost controller had this pill in the end of it as seen in photos. Other than the obvious (T28 Ceramic turbos might well be cooked)  Can anyone shed any light on if there is any validity at all with this mod, bleeding a constant fixed rate of manifold boost pressure off through this 3mm hole?  Is it deliberate?  Was this a 90s Jap mod done to RB26's? Or has someone just fitted this without any idea of what happens to ceramic T28s if they are not gate controlled?
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
