nope. against da law mang.
they arent able to defect on private property, in yo garage, on yo driveway, in a shopping centre(unless they pulled you over from driving on a pubic road)
Shopping centre, whilst private property - Is still deemed to be of the public interest, so from my understanding you can still be pinned.
This is how they smashed people a few years back at the Autobharn evening car show thing that was on @ Chaddy and caused an epic uproar in the community over it all. Not that the Police cared of course and hasn't been another event like that since.
Whether a boom gate @ the front makes a difference or not I don't know.
I do know however from experience... If there is a offence reported (criminal) & Police believe someone that has committed the criminal offence is within that Private Property - then they are allowed to enter. So dropping a bottle would constitute this if they got technical.
It's a very grey area.
But yeah, everyone will probably get EPA's in the next 2-3 weeks. It's far easier to do a EPA than it is to do a defect. Less paperwork and you cannot argue it in court as easily as a defect.
Yeh but if the incident reported was letS say was violence, then that's what their priority attendance of the matter is. They still aren't allowed to then go and defect the vehicle as they really can't prove how the vehicle was transported there. Shopping centers may be different as they are generally gov funded so could be right but epark and all that are privately owned business'.
A very recent example. A mate of mine, renaldi. Has a very modified supra with a f**king stupid high mount.. They couldn't get the car started in his garage due to a cooler pipe. So every time the car did fire over they would gas it abit to keep it going.
Next door neighbour got pissed called the cops and said he was doing burnouts up n down the street lol.
Cops came, without a warrant they aren't allowed inside Renaldis house, but to avoid further issues he let them in to see the car. Cops basically said we cannot defect you here, even with the Vic plates on, but if we see this on the road ya f**ked.
This was only a few weeks back. So I don't really think having a report has much to do with it. The easier approach for them would be to black list the plates they took down and/or EPA them. Which apparently a lot of the people at JDMST got defected last night so I wouldn't put it past them for a black listing
someone threw a bottle @ a HWP car yeah? i'd be VERY surprised if every single car doesn't get an EPA in the mail.
JDMST is too fkn fashionable for me anyway.... i feel like a dinosaur at those events... dudes in dicktight jeans around their knees or in womens tracksuit pants for some reason... IMHO dont worry about defects.... throw 'em all in jail until they are old enough to dress properly
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
