lucky. was gonna ride to tafe after work but i aint getting on a bike unless im 100% fit and in the mood lol
also i prefer the look of the longer stock levers :/
Took some pics for ya today. A week of polishing and waxing, finally finished! And all blacked out, how it should have been from factory...
Visual mods:
Tail tidy / fender eliminator
Black windshield
Smoked LED indicators front and rear
Yoshimura pipes
Yoshimura rear sets
Pazzo shorty levers
Motogems bling kit (random gold bits etc.)
Green LED park lights
Removed pillion pegs
I wanna do something with the mirrors and then I'll be happy (for now lol).
I dig the black and green personally. Looks baws.
in4evos
Glad someone does. You should see it in person at night, the pic doesn't do justice. If I wasn't doing the black and gold theme, I'd slap on some Monster energy drink decals!
Lol toby I wasn't lying when I said it was built from the bottom up, there's another 2 A4 pages worth to add that I couldn't fit in the ad so I just added the important shiz.
Lol pat, my real need is for another four door, and the evo has the power too
SO you tune was that maxing out the injectors?
yeh, base pressure of 35psi. i can bump the pressure to about 45psi and run a couple of more PSI boost should see comfortable 290kw. wasnt bothered just yet as was going to go 2000cc and e85 and smash 350 out of it..
and yeh ive seen that serial number lol.. i didnt know what it was until just then lol thanks.
After seeing your mods list, and seeing as your getting into tracking I would be more inclined to keep Sunkist :/
hence the price, if someone pays it, they can have it. but if i was to put sunkist into a wall - repair bill will not be friendly.
cool, I'm looking at some 1000's and e85 hoping for the 300ish zone, might go for some more as it will be getting built for WTAC.
Sooo can Habib and I take it for a spin in the industrial estate?
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
