Yes might not be able to move it without Birds/Dezz/Rimon
with their powers combined, blah blah you know the rest
Got a Nistune.
Nope can't start
Just splutters and dies
would need a MAP sensor for that wouldnt you? to get it to run i mean
Nein, it's basically 'modified' stock ecu you need AFM reading for the ecu to work.
yeah but if the cooler pipe is off, the actual air in wouldnt match the airflow measured at AFM and car would die. wasnt sure if nistune can run MAP, and im not sure hop MAP works either but thats what my brain told me to type.
From memory, Nistune can't be run as MAP, even if you try, you'd better off with Link/Vipec/Apadtronic/Haltech/Microtech/Motec/Autronic/whatever really.
Finish doing my reps of 100kg bench, feel pretty boss...Maori guy on the bench next to me does 130kg x 12-13, bar moves like it has no weight on it and he doesn't even breathe.
Yeah ive been meaning to buy a pfc for a while now.. Though so much better new stuff, pity about the prices though :/
It's better but you don't really need it unless you're building an all out monster. Race Pace will make a Skyline with a PFC feel like factory, that's how my car runs, only with twice the power.
PFC ftw
Oxygen sensors, not so. Can't drive my car til Monday :(
If you know your way around HC I think you can switch O2 sensor off.
That is what I did when I had my 33r tuned.
Just unplug the flamin mongrel. It does the same thing. Lol shell be right
PFC works. Everyone knows how to use them.
If you want flex, link or haltech
If you want data logging and dash haltech or motech.
There are some others in the mix, but why would you take the risk.
Yeah the issue isn't the O2 sensor functioning, otherwise I would just unplug it. It's the hole I have in my dump pipe because I couldn't plug the threaded bung with anything but some sort of brass and plastic sensor/plug, of which the plastic has melted off, creating what I think is a hole in the plug. Don't like the idea of hot exhaust going straight onto other pipes and electricals, so I'll be making one more drive with the thing and that's to the exhaust shop.
Oxygen sensors are good things - when they function correctly you will always get better fuel economy out of them than you will running closed loop all the time.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
