fat rimon
fyp
Yeah I'm about 72-74kgs been training for almost 2 months I'd say. Trying to keep form good on current bench weight hopefully soon I can lift above body weight! /powertoweightratio
Started around July and hoping to hit 80 by the new year (was 68kgs)
Also, LOLed at giving your mate a blood nose
pretty good effort :thumbsup:
Anyone going to the MotoGP or wanting to go?
wanting
f**k my 2fiddy sounds good. i think if it was a bit bigger i wouldn't wanna sell it :sleep:
wanting
I might put together a small group to ride down on the Sunday; got a couple interested. Be my first year there on a bike.
Drive through Springvale windows down, random comes up and says nice ride man...thought he was trying to rob me...it's just been that long since anyone has received a compliment in an R33.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
