Cheers!
But wouldn't it bulge out too much?
Shouldn't too much. Dad has 245 on his ford, that's a bIt much lol
I drive a golf, you opinion is invalid for traction...... 205/40s it is then :P
Conformist lol
Out of stock! Just ordered 3 packs from US eBay on your recommendation. ~$25 delivered lol. Still pretty cheap if it does what it claims it does. Lots of people saying good things about it on the Internet.
Oh I didn't buy it through there, my colleague ordered off eBay. They definitely work. Wait half an hour after taking one, lie down in a completely dark room and you'll fall asleep pretty quickly and stay asleep. I was pretty sensitive to the 3mg dose at first and it made me feel hungover the next day but my body got pretty used to it and I'll wake up feeling awesome and refreshed. You might need to adjust your dose once you work out what your body needs. I probably take them once or twice a week when I know I'm going to have sleeping problems. It's a hormone your body naturally produces and it's shown to have a lot of positive health benefits, so in moderation it can't be bad for you. You can't buy them in Australia without a prescription, in the US you can buy them from the supermarket. No issues importing them though.
For the nights I cannot sleep at all Stilnox is the only answer, and it knocks me out cold. But I'll only take it as an absolute last resort.
Edited by llama_au
Yeah it sucks balls. Mine was hitting a ripple strip side-on and getting airborne. Expensive day - two tyres came off the rims (but thankfully were salvageable), scratched the rims up a little, stuffed a rear hub and put cracks in the front lip. The solenoids in the transmission also packed up shortly after. Think it ended up costing my about $1200 in repairs *sigh*
polished existing Slant lips. 17x9+20 all round with 225s
might run 15mm bolt ons all round
I would hope so, I'll be running 17x9 +22 on the golf rear :P
BBS club represent! Might also need some slight gaurd rolling although wheels are the same offset as already on and they don't rub at the mo. However need to mod exhaust to run a little lower so will have to look again. Tracking new lips and outers/bolts from Germany at the moment.
Quite oh my!
Is that the going rate for rolled guards these days?
Oh my.
Careful how much you order, customs usually take an interest as it requires a prescription in Aus
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
