lol at 7 people
I never stated how comfortably but there are 7 seats and 7 seatbelts. I do recall one hill foot flat to the floor and revving the tits out of it I managed 35kmp/h - I assume they never intended for it to carry 7 Australian-sized adult, 3 eskies, bags of ice, slabs of beer, etc to and from a festival. Never again do I offer to be taxi because I own the people mover lol
^Hope this weeks flies by just as fast! Some assignments due in next few days, but temporary freedom come at me Friday night+
Long awaited mid-semester break... After 3/4 of semester lol /monash logic
same as ours is end of march!
for us it due to the June EOFY is some of the busiest time of the year, so we don;t want to be doing our books at the same time we just want to be selling as much as possible.
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
