f**k this threads dead today
Perform a CPR.
On another note, f**k, I need new work pants even though I've bought couple other days, it felt shit and makes my genitals all over, I had to adjust it every f**king minute...
get some new jocks brah
No issues with jeans, tracksuits only this stupid useless 'business' type pants...
Might have to go one size smaller me thinks, time for another trip to clothes shops - f**k it
When i was a kid i used to wear boxers, did karate when was young and eventually when my balls dropped i needed to upgrade to breifs :(
You need an ipad or something for the train play some gameeeeees
18x10 +38 nick :P
yours should be this low!
That's bagged out, just like most of the US cars, also no way in hell he is running 10 +38 front won't clear strut. I'm pushing it with 9 +35
my rears are 9 +22 so will sit 3mm more out
I reckon mine sits at a good height atm, will need to post up a side pic soon to confirm for wastelanders
    • I thought it could be an issue because the standard plate was flexing when stressed. Maybe the original gear set will hold a bit better without flex? Last time on the dyno it made around 670nm at the hubs. Now it have bigger turbo and better intake but have not been on a dyno yet. The car is being used from family trips to drag race events. So the shifts can be a little violent. It is grinding if I shift to fast so was thinking I should overhaul it soon.
    • From the factory on RB26s there's a fitting on the intake manifold collector/"plenum" that provides pre-throttle boost signal. That's how they did it back in the day, I figure it's fine to replicate it.
    • I would be surprised if that wasn't the issue. It's probably telling you, that even if you remove the plastic liner, you may have some other clearance issues that may occur too in some scenarios. IE, tyre to guard. It looks like someone has already rolled the lip, but you may still have issues in the future IE, turning and hitting a bump etc. The fact it changes how bad it makes the noise when you are going backward vs forward is highly indicative that it's the tyre rubbing. They do make a terrible sound, even if you're only pushing a project car that has a liner hanging down on a tyre!   Has the car been lowered? If it has been, what is the measurement from the centre of the wheel hub to the lip of the guard straight up?
    • Summernats cruiser?
    • Mark's a bit smarter than people give him credit... He'd convince the person that is to become dead, to drive him to the forest first. That way his car has no evidence in it, and he's free to dispose of their vehicle permanently how he sees fit too...
