anywhere you go just watch an Anthony Bourdain and copy where he goes... you can NOT go wrong
also should read his book "kitchen confidential" fkn GREAT book
yeah just recently been watching his shows.
and on the opposite end of the scale man v food.
Lol i'd love to know what for
Serious.....
I guess you didnt see the picture of the hot girl bent over the stairs with only a pair of stockings on and a buttplug that looked like a horses tail...
It was totally worth it :yes:
Serious.....
Lol if he posted that why is he wondering why he got banned.
yeah yeah i know everybody's seen it and it's an epic repost but still... FUAAAAAAAARK THAT
Sparkies brah
I'm gonna be in Epping tomorrow, have 30 minute lunch break....Suggestions on things that I must do in Epping?
Please respond.
One of Melbourne's many shopping centres, Epping Plaza, is located 500m away from the Epping railway station. The Northern Hospitaladjoins it. Dalton Village is a small shopping centre which is located on Dalton Road in Epping. There are many parks and reserves located throughout the suburb.
epping has a brand new train station could check that out..or just up the road is the all new melbounre market...pretty big deal but not open to public yet...
other than that epping sux ....
Birds demise
http://www.skylinesaustralia.com/forums/topic/409240-wtf-plug/
basically adz banned him for posting porn again....
Keep in mind I need 5 minutes to get off site and 5 minutes to get back on, so 20 minutes sight seeing time
Birds demise
http://www.skylinesa...09240-wtf-plug/
I work at the market relocation lol
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
