a drop top ferrari 360 was parked right on the edge of my driveway a minute ago...
then some muscle-mary douchebag came out of the house opposite (tight chesty bonds and a gold chain etc etc) and is showing his mate...
clearly daddy's car as he didn't know how to open the bonnet and also thought the engine would be in there.
you should have heard how badly he was riding the clutch when he was trying to reverse it... provided soooo many lulz.... infact ima put this post in the lulz thread...
Eh? Won't the lips stick out just as far? Unless you're running spacers that you'll be removing?
What he said.
WIll sell the 2 x 6.5in 34 hole barrels (brand new but powdercoated dark charcoal) - for $400.
Washed car - shopping and then did the Eltham - DIamond Creek - Kangaroo Ground loop - awewsome day for driving. Going again!
will raise the offset as the center section will sit in a little more as the barrel is smaller
nah ill pass for that kind of $$$, can buy 2 brand new lips for that
Will just make these fit
Couple of young fellas in a Gallardo superleggera on lygon last night gorgeous car, but them looking towards an old bloke at a table when someone asked them to give it a rev and him nodding lol, wish my dad had a lambo..
The centre is bolted to the hub.. I don't think it's going to go in any further?
Actually sounds more logical than my alcohol filled imagination that I'll be going smaller than what they are now :P
http://jalopnik.com/5944568/is-a-15+year-old-texan-girl-driving-this-ultra-rare-lamborghini-to-high-school
Nah was f**kup on our side, the way the standard lips are to the wider lips we calculated wrong
So new lips will stick out 12mm more than I originally was thinking
You would think that, but not if you saw how they fit currently :P
haha oh it will be ;)
needs way more camber first though :P
lol damn i see what you mean now!
camber / flare / stretch!
lol worth a shot, will look crazy if you can pull it off :D
    • Put a fuel pressure gauge on it. Replace the turbos. Probably completely separate issues.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
