You're spot on. I just smile at everyone who complains about cop attention at meets, they made it this way! I think the last meet I tried to attend was a JDMST meet a couple of years back. Cops attended the last ones I went to and fair enough, I would to if I knew there was a high chance someone was going to do something stupid. Gone are the days of large meets where everyone just stood around and talked, chilled and appreciated eachothers cars.
yeh the funny thing is, it was all fine.. everyone was standing around talking, there was a yellow 34 with some music playing for everyone, there was shisha.. people were walking around talking just enoying it.. even a dumped delorean came!
then this cadbury chocolate rapper decided to fiddle with launch control, and did skids then left and came back for a 2nd round of launch control
everyone after that just followed suit i guess. such a waste of time now.
Ahhh so you ended up going to the meet Aaron, I only left Scotty's at about 8:30 lol
Going by how these hardtuned/jdmst meets are going, once day cops are going to come and block every exit and start defecting every single car in the car park
it's only a matter of time....
this is why i dont do meets anymore :/
depress clutch
rev to redline
drop clutch
this method would skid a lawnmower
lawnmowers don't have a clutch..
ours had a pedal you press top it go forward you press bottom it go back,
so get on concrete get momentum in reverse hit forward.
front wheels lift inch, 1/2 meter skid I was happy..
Dad not so much..
Yeh it was relatively good to begin with. Then the above purple s15 started and everyone followed.. The only cop that rocked up was a normal divy van. I thought perhaps either they were pre occupied with the city and possible Muslim riots.. Or actually give the people a chance.. Buh eh. When there's cops, they complain, when there's no cops, they do skids. Children
depress clutch
rev to redline
drop clutch
Armed with this 'new info', totes time for some 'meets' xD.
i do realise lawnmowers don't have clutches... it was just the least powered thing i could think of without resorting to jonoe's car
LOL
Edited by kaitoukid
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
