Dezz, Rimon just watched this video (filmed in melbourne), DAT SOUND 7:05 stock as well :O
looks like he starts/finishes at one of the shops on elizabeth st/peter stevens
onboard sounds heaps like my 2fiddy...
nice bike too expensive
Edited by R-SPEC
62% flour, palm oil (wont hurt you unless you are an orangutan), tapioca starch, salt, acidity regulators 501 and 500, thickener 401
so in reality it's flour, oil, starch, bi carb soda, mineral salt and seaweed......
actually not that bad at all
the flavour sachet's however are actually 101% msg
ingredient make-up is one thing, the process of over-deep frying in oil is another thing haha
lul what?
Find that hard to believe haha. I'll ask my boss at work who used to manage a factory which made instant noodles. Wont name any brands due to public forum :/
Basically, instant noodles are deep fried noodles cooked in a lot of oil. Most likely because they are soaked in oil from the beginning thats why they dont stick together.
/FMCGknowledgeAustralia
They stick together case they dry and hard as fuhhh. Water gets into them and they just go all soft.
your all f**king Asian lol
Nong Shim iirc the brand is the only one I liked, was spicyyyy and good
But heard that and stopped eating them, was on news or something i think i heard it
http://www.snopes.com/food/warnings/noodles.asp
Maybe my technique on bench press wasn't the best, held arms a bit further out and felt a little easier tonight? Unless I'm getting stronger :D
If you hold your thumb out, tip of the thumb on the edge of the knurling is a pretty good position, assuming standard knurling.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
