re the beers my fav to date has been the
dinkelacker hefeweizen helles
A small stuttgart brewrey
there are a couple of aussie micro that I like
white rabbit
Hawthorn brewrey wheat.
(noticing a trend here)
but better question worst beer..
from korea
OB Blue
tag line taste the blue technology..
(I think by blue they were using those old blue toilet cleaners to clean the gear
agreed - (that or anthony bordain's job)
yeah.... if you see him tell him to come to my place and pick up his bar stool
lol was with him last night, he's a friend of mine... Were you guys Sharing the bar stool?
yeah I bag him for owning a vw too lol
Best beer I've tasted was an IPA from New Zealand...can't remember the brand, but could probably recognise it. They had it on tap at the Station Hotel (?) off Greville St and it's the first beer I thoroughly enjoyed...as opposed to an acceptable tasting alcohol for getting pissed (usually Carlton Draught/Cold).
Edit: the beer was Tui East India Pale Ale
What do people think of wrx? I inspected one for a friend yesterday and was actually quite impressed and are in the same price range for an evo. What u dream boats think
Owning a Rex and mate has an evo, I'd take an evo. Way easier to make big power on an evo than a Rex :(
Yeh and cheaper to build apparently..
If someone sells my car for me ill give you $500 I found a few evos I want
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
