re the beers my fav to date has been the
dinkelacker hefeweizen helles
A small stuttgart brewrey
there are a couple of aussie micro that I like
white rabbit
Hawthorn brewrey wheat.
(noticing a trend here)
but better question worst beer..
from korea
OB Blue
tag line taste the blue technology..
(I think by blue they were using those old blue toilet cleaners to clean the gear
agreed - (that or anthony bordain's job)
yeah.... if you see him tell him to come to my place and pick up his bar stool
lol was with him last night, he's a friend of mine... Were you guys Sharing the bar stool?
yeah I bag him for owning a vw too lol
Best beer I've tasted was an IPA from New Zealand...can't remember the brand, but could probably recognise it. They had it on tap at the Station Hotel (?) off Greville St and it's the first beer I thoroughly enjoyed...as opposed to an acceptable tasting alcohol for getting pissed (usually Carlton Draught/Cold).
Edit: the beer was Tui East India Pale Ale
What do people think of wrx? I inspected one for a friend yesterday and was actually quite impressed and are in the same price range for an evo. What u dream boats think
Owning a Rex and mate has an evo, I'd take an evo. Way easier to make big power on an evo than a Rex :(
Yeh and cheaper to build apparently..
If someone sells my car for me ill give you $500 I found a few evos I want
    • New CAS just turned up from NZ Wiring. Looks like a nice bit of gear.  So, yeah. Triggered, bro. Realised I may as well do the cam belt while mucking about with it so will order one of them.
