wrx is basically an underpowered evo with a weaker gearbox and higher percentage of cars with mini boxing gloves hanging from the rear view mirror
I lol'd because the last WRX we had in at former place of employment had the gloves lol. What the f**k is with that.
I've got 200x 5mg coming in, you want half of them? I'm fine with half that dose so I'll be cutting mine in half.
That's really generous, I think I'll take you up on that. Just lemme know when / how much I owe you and I'll drop past, cheers :)
try this guy, these are where I got mine and they came in pretty fast too, not sure if that cheap compared to where your looking but they have stock at least
Tried it last night and works great :)
http://www.ebay.com.au/itm/320862768874?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649#ht_1661wt_1163
Thanks! I'll add to favourites for a future order.
What do people think of wrx? I inspected one for a friend yesterday and was actually quite impressed and are in the same price range for an evo. What u dream boats think
Guy I worked with at honda had a new wrx sti - went through kinglake twists and to be honest that thing just stuck to the road, I was actually really impressed
true, but still... evo > sti
WRX drive well and make a decent daily compromise for a sports car...definitely felt more comfortable putting around in one than my Skyline. I was surprised how well it pulled for a 2 litre engine too. But...bit of a boring vehicle in a stock configuration. They aren't really pretty inside or out and they're pretty old hat now, like Skylines.
Wonder how long the "Evos are the shit" buzz will last on the import scene.
yeh i dont know whats happening with the car now.
after going for a spin in thats wrx yesterday i was very impressed - but supposedly $90k spent on it.
after driving an evo stock, i was still fkn impressed at how comfortably quick they are. good daily
ive found a few evo's i want, but now realising that i will probably regret getting a four door if its not an evo... seeing as a company car will(should) be around soon.
which then leaves me to, is there a point in selling mine? or do i still want a "change"
33GTR's are starting to catch my eye aswell..
my mind is full of f**k
Keep your car and track it pusssayyyy!
Otherwise Evo or 33R
Post links to the Evos your looking at brah
the evo is on sau..
white evo 8
33gtr havnt really looked, just liking them more and more..
Drove one ages ago, wasn't that impressed, only nice thing is boost comes in early but there's nothing on top end, that's it.
Want 300kw plus? Replace essentially everything, f**k that!
Mohomo, lower it more.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
