You got some balls Ashrey
I've seen many small businesses come and go
Hope you run the business well as with the new DPN provisions you can still get royally screwed even if your a company entity.
Well at least with all the equipment you'll be purchasing you'll be able to make good use of the new depreciation laws :thumbsup:
Not so much balls, just good homework and business financials that we pulled apart (i'm in with 3 mates).
One of those happens to be a really good accountant ;)
So ye, all covered on that side, he is doing the books lol
Not sure how discounts and what not are going to work as such, I've got a big 8 weeks coming up to get it all sorted (it's a bare shell at the moment).
Rest assured though any SAU guys that come down and bring friends etc, I'll be sure you look after everyone - and we'll have the best steaks in the east :D
Haha sounds draining yet exciting, man. Nunawading fairly close to me, so if those steaks are as good as you say they'll be... :D.
Edited by kaitoukid
lol my restaurant will be 100+, and I'm front of house.
Going to be fun times ahead, but then I've done it before a while back, should be right!
I had no other waiters/waitresses most of the time, it was just me.
rims ordered, anyone got pics of 245s on 9.5"?
hopefully have them on before SnS
What did you buy?
I've got 235 Federals on a 9.5" rim, they are pretty wide for a 235 so should give you a reasonable idea.
Pics in r33 thread
have you used the tomei one before?.. is it better then a lock bar?
Nope, it'll be my first time, will report when I've got it and have it installed
In theory, it could be better than a lockbar when it comes to a time when you need a RWC. But we'll see...
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
