I don't find this heat that bad for riding...with a vented textile jacket it's alright while you're moving. But I'm not jumping at going for a ride either...
40 degree days, I've ridden on one of them and, stopped at the lights is your own personal hell.
yeah true not to mention bike will probbaly catch fire lol
very tempted to take it out now eventhough windscreen is off. just washed it looking all pretty n shiz
R6 probably the only side exhaust bike i wouldn't mind having. delicious.
Rode on Tuesday, only get hot when stopped... oil temp got to 106 at the lights but drops 20 degrees as soon as u get going again
Mates gixxers have fans that kick in around 106, not sure if mine has one or what temp it kicks in at
What about the bag of boost alvin? :P
f**k that bag of boost, who wants boost!?!??! i have heaps, come grab them. i want chocolate, not biscuits and sugar.
I'll give you a choco Alvin if you make me some of this so called magical wagyu of yours!
Lol.. unfortunately, this batch has sold out. sorry brah LOL i dont even have any samples left because my scumbag housemate took them all.
You know if Nick's (Arma) 4dr gtir conversion was ever finished after he sold it?
Oh gosh, that's testing my memory. I thought you were asking if Arma finished it at first. To be honest, I have no idea if it was ever finished. There are a number of 4-doors with GTiR running gear getting around, even someone who bothered to do it to an N15.
Edited by llama_au
you got too much time on your hands :P, I had 3 little girls ring the bell, gave them those big caramel koalas
cos im not a flamin mongrel
It's that or give them some of my marble chocolate...
Haha, just thought I'd see. I want to uni with Nick, so knew his was one of the first and he'd sold it before it was completely finished. Was an awesome conversion though, very stock looking.
Haha sitting there at the lights watching the temp gauge go up with paranoia. Amazing what a bit of air flow does, almost instantly. My bike sits around 70 when riding but can get as high as 108 sitting in traffic and the fan kicks in around then I think.
Anyone seen the movie Zombie Strippers?
Friend told me about it and it was on tv before.... little bro flicking through channels and was like wth! hahaha
Huh? It's on channel GO! at 11...
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
