Credit card - then do balance transfer to low interest credit card transfer deal
e.g. http://www.citibank.com.au/aus/credit_cards/cards_platinum.htm
Just don't use the card for anything else. Shop around for other deals though, the citibank card has a $250 a year fee
Still can't believe they offered one once with 3.99 for the life of the transfer
Would a Victorian unregistered vehicle permit be valid in nsw? So I can drive my car from the hotel to the show n shine
Also remember a unreg permit is meant to be only for getting things done to register your car.
So if you get pulled over up the Hume, you will have a lot of explaining to do, and if not sufficient permit goes and you call a tow truck.
Hambo - 2 days this week doing 6hr shifts in a kitchen - knocked the stuffing outta me, but must admit I'm highly enjoying it.
Will get used to it in a few weeks no doubt.
Cant wait to get open!
hahaha so in total you did 1 average day (well only if there was no break) ;)
opening you own place you will probably end up doing 80-100 hrs a week untill it's making cash back. EOTD every 40/w you d is 50k a year that you aren't paying somone else to do it .
we still need to have that drink... you free this week?
Got a 10k limit on my credit card... But think for cash advances the interest rate is stupid high...Don't know coz I've never used cash advance.
Might be an option considering most personal loans charge a fee if u pay it off within the first 12 months...
Hamish & Andy, insider opinion?
Personal loan is the safest option.
atm westpac are offering a 12.9% from memory.
dont go the cash out then balance transfer method, as you will then have 3 x enquires on your veda report within a year and the balance transfer might get knocked back.
what is the story with your homeloan? is there an interest only portion? cos if there is i'd be staying away from excess credit until this is over as the loan will be reviewed at when it reverts to principle and interest.
personal loan is the safest option if a 5k redraw is not available to you.
just remember that every redraw will be visibale to a banker when you wish to restructure the product, and as such you always want to keep this at a minimum.
with a credit card you have to be more vigilant and make sure the payments are made on time, not early, not late and if you pay just the minimums on 5k you will be paying that for approx 15 years, whereas a personal loan will be 5-7
yes they are, on their flexi loan til the end of the year
He already has the CC though, so should be one less? Probably my circumstances, but never had any issues with my report to date.
Yeah, fkers, late fee for paying early :-/
It's not a late fee for paying early, it's because interest is calculated monthly, so if you pay early then your payment will count towards the previous month and technically you haven't paid the current month... Jus made a double pay for the previous month.
    • Not sure the US can import anything other than the C34 Stagea's, but if you can and you need to to tow, DO NOT under any circumstances get an M35 Stagea. If it is just as a family car and your country/state allows it, absolutely and definitely get an M35 (3.5L if possible as it is effectively a 350Z) over a C34.
    • Punch your VIN (nm35-xxxxxx) into Amayama.com You can see everything there quite easily.
    • Thanks for that, I'll check it all out. I can always do the brakes last anyway if its a problem.  The 16's are super cool, if they do fit I'll cruise around with them for a bit.
    • Well, that's kinda the point. The calipers might interfere with the inside of the barrels 16" rims are only about 14" inside the barrels, which is ~350mm, and 334mm rotors only leave about 8mm outboard for the caliper before you get to 350, And.... that;s not gunna be enough. If the rims have a larger ID than that, you might sneak it in. I'd be putting a measuring stick inside the wheel and eyeballing the extra required for the caliper outboard of the rotor before committing to bolting it all on.
    • OK, so again it has been a bit of a break but it was around researching what had been done since I didn't have access to Neil's records and not everything is obvious without pulling stuff apart. Happily the guy who assembled the engine had kept reasonable records, so we now know the final spec is: Bottom end: Standard block and crank Ross 86.5mm forgies, 9:1 compression Spool forged rods Standard main bolts Oil pump Spool billet gears in standard housing Aeroflow extended and baffled sump Head Freshly rebuilt standard head with new 80lb valve springs Mild porting/port match Head oil feed restrictor VCT disabled Tighe 805C reground cams (255 duration, 8.93 lift)  Adjustable cam gears on inlet/exhaust Standard head bolts, gasket not confirmed but assumed MLS External 555cc Nismo injectors Z32 AFM Bosch 023 Intank fuel pump Garret 2871 (factory housings and manifold) Hypertune FFP plenum with standard throttle   Time to book in a trip to Unigroup
