damn the 1 and only FWD I have owned handled like a bucket of crap..
I almost wore the writing off the side wall off it...
couple months later, with some thick as sway bars
whiteline springs
18inch rims with decent rubber
over steer city and such a great handling car.
took quite a while to get the s14 to turn as well as it did, but now...yeah no turning back.
I'm towing it up on a trailer, permits just to get it to the show n shine.
ill see if a mate let's me borrow his trade plates.
ah well in that case get a NSW permit..or better yet
GET THAT MOFO REGISTERED!
Played here today!
Highly recommend it for anyone who plays tennis, the atmosphere is surreal, even if no one is watching haha :)
this?"]this?
Edited by kaitoukid
Played here today!
details?
would love to take the missus here
got invited to Wimbledon once...regrets massive
Fuck I hate cockblockers. Oh lordy lordy how I hate them. The worst of the lot would have to be the jealous and taken girl who cannot even be wingmanned.
Nah we had the court for three hours...finished with a tiebreaker too! Will get a phone number for you Marty...gf of a mate booked/paid for it as a present. From memory it was about 80-90 for the three hours.
if its open air, the risk of explosion is low.
Mate have you not seen Today Tonigh/ACA's expose on barb eque dangers they dust off every 6 months or so? They even have "an expert" to chime in so it must be genuine.
birds apparently they re made the mountain hwy road so just be careful next time you go up.. some random bumps now or so i hear..
When did they do this? I went up there the other day, hit a fkin bump accelerating in 1st and nearly flew off my seat. Shit wasn't there before and I can't spot any potholes in the vid I took :/
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
    • Wouldn’t touch par if they gave it to me. You need to ask how much power you’re looking to make and then add about 50% to it because that’s what you’ll end up making  The factory box says no more at about 350kw or so, the upgraded synchro boxes won’t handle much over 500kw for long and at that point you’re looking at an auto or dog engagement manual,  once you’ve gone dog engagement you may as well go sequential, they cost a little bit more but it’s worth it  also while you’re at it you should upgrade the transfer case with 10 friction plates
