Yeh the 8mr and 9 lights are black. Will change them eventually. But happy to keep as is for now and just enjoy if
You can paint them to look like the later lights, also you can paint the projectors different colours as well like red/blue/purple etc and looks great
yeh but cbf with softening the urethane pulling apart etc.. especially if I break it..
paint the projectors? lol thats a bit queer isnt it? lol
Nah its pretty easy, I did it before i swapped with my brothers 8mr lights before he sold his
I painted my projectors yellow to match car and looked pretty good, but I got MR lights only a few weeks later so wasn't on long lol
its just a part of the light trim you paint on the inside when you pull them apart
oh so it doesnt change the physical colour of the beam, just the lense reflection? plus the cars white.. not much going on for me to match it.. unless i do it orange and have that as the sunkist theme lol
hmm if its that easy, I may get you to come help me when I decide to do it..?
for all you watson fans
Am I missing something in this pic?
Also lol at someone asking 12k for a NA 34 with damage on rear bar and has also been into a pole previously
Are you referring to Jess's car?
Nah just a small piece that you paint, can always change to different colour if you don't like it
Lots of the evo guys go red on a a white car, although I've seen purple and looks good too.
There is a thread on evolutionOz.net that shows finished ones and how to do it
Yeah sure, I'll give you a hand
i might do orange lol. would match the indicators and i need something orange on the car, but just something small and subtle..
i wont do it soon.. might be a couple of months.
thanks!
    • oh they were with that motor, you need to remove the engine to change the spark plugs (don't have to, but it does make it easier)
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
