7Watt LED's (400 lumen yo!) for reverse lights to help aid my reversing at night with 20% tint.
Stock Halogen:
Stock Halogen (rear view mirror):
LED vs Stock Halogen (Rear view mirror):
Stock Halogen vs LED:
LED vs Stock Halogen:
I feel sorry for people behind me when i reverse. At 10 meters away, looking at the beam of light, it like looking straight into HID's.
$350, yeh, i'll do that...
it's all plug and play with the MR turbo yeh? and all up the front of course
Yeah all plug and play.
Also can just buy a 10.5t housing for the rear and modify the stocko
Thats all that's bigger 7/8 run 9.8t and from 8mr/9 they run 10.5, would be cheaper probably doing it that way but a bit more hassle
pretty tough, people have too much money though
also needs better front tyres and to weight down the front, would be dangerous driving down the road at high speed in it
Our tractor at 30km/h is all over the road, they aren't meant for high speed, especially with skinny tyres
Stock Halogen:
Yeah I've got one in the Golf, works great
My mate, saw a prelude for sale, wanted his lip kit. This is what happened:
bad English is a necessity
i always get buff before i go and see an orchestra
FYI the ACO were amazing...and I'm pretty sure I had the biggest bench press there. Incidentally, the next youngest person was also at least 45 years old.
not the first, but here's another perfect example of a timewaster: Miguelone
i drove 60kms to meet michael 4pm saturday afternoon, 4:30 tried calling, sms, nothing.. come 5pm i recieve an sms 'oh hey mate i can't make it today - anytime tomorrow is fine'
so i give michael my other address 30kms away, load the parts up in my boot and arrange to meet him 10am the following day - to my surprise he doesn't turn up, doesn't answer his phone, doesn't reply to sms, yet is capable of posting on SAU.
people like you ruin this website! i know traders that deal import spares comercially and dont bother with trading online as too many people like yourself!
Rear subframe brace?
Also this bracket & mounting hardware if you have it.
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
    • Mine is all -12, I’m running a dry sump in a billet block though
