well heading back from SG now.
And like to thank wastland folks for suggestions.
had some awsome food
more so as a Big Seafood fan.
as for the marina bay sands.
such a let down.
rooms small
service the worst I had in years
pool ok its nice
seems that it more a tourist location rather than hotel,
and that's how staff treat it
I will not be going there again.
anyhow
got some glenlivit and some patron Duty free so life not too bad.
M
oh you were there in sg hey?
mbs is soooo overrated, but, then again, i dont really know hotels in singapore. so i wouldnt have been able to recommend any anyway.
Took the day off work and I'm sitting here patiently waiting for The Thread Doctor to arrive.
Removing a snapped dump bolt from my turbo rear housing, and 3 exhaust mani studs from my block.
What are you guys up to today?
coilpacks +1 :(
need some new puppies in mine too. but mine have been dying for a while LOL.
coilpacks + major = happy days
hopefully.
*soon*
Edited by kaitoukid
hey hamish, do you like fuel economy?
if yes, then you wont like the evo lol.
probably why I wouldn't go back to a performance car unless it's a straight weekender after the golf
diesel is awesome economy :P
once tuned it's not going to be worse than my 300rwkw skyline man
lol no worse?
you're in for a suprise lol
its not even so much economy.
major PITA having to fill up all the time because of the small child sized tank..
that and the turning circle lol.
the only two faults i have with the car...
replacing the o2 over the weekend to see if it makes it a little better as the o2 looked as if it was all over the place.
currently 250km to a tank.. stock. fun. no
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
