Nah roof is high enough should be ok
I'd be more worried about cutting the hole under a joist...
Have fun with the plaster dust lol
Yeah gotta get up in the roof and sus out the positioning first...
Feel free to PM me with how you'd go about it all....I think I've got it worked out but first hand experience is king
Dezz I reckon the older style tail lights look much better might look into modding that in down the track and relocating indicators problem is most of the kits on ebay have the crazy illegal number plate positions lol
Should pick it up tomorrow if it passes rwc okay
Edited by UNR33L
Yep, more cops rocked up after bunch of emos left. Might been you and your friends?
And cops blocked 3 exits, 2 on same street and one towards Jersey Rd.
4 cop cars, 3 UC and one HWP.
lol nah i was gonna stay and watch, not having a defectable car is fun, but samir and daniel wanted out because of theirs so i left...
made it better when people were doing skids in front of the hwy patrol.
sif not say hi grant..
lol I should have stopped by, would have loved to see some f**kin tools doing burnouts copping a yellow sticker and a f**k off fine.
Saw Tone at Cold Rock though :)
Sorry!
Mike and me watched for a while then I decided to bail while we have the chance.
What did you wanted to sell?
yeah, I reckon it looks heaps better above the exhaust
Already done mine... just waiting for my exhaust to arrive so I can complete the fender elimination and install the new indicators. Will look sick when it's finished
    • I was using the wiring diagram I have So 12.74V is coming into the rear Fuel Pump relay as I measured.  When I turn the key to ON im getting 0.6V to the Fuel Pump plug; which i assume is backfeed voltage and doesnt include the 12V from ignition power.  The rear relay is working and being triggered.  From the diagram I clearly see the rear relay 80 = Rear Relay going into the Body/H loom (R-27) 27 = Fuel Pump plug going into the Body/H loom (T-20) 40 = Short Connector (R-27) I'm reading 12.74V on the blue/black wire which is the power for the Fuel Pump   From this diagram I can see the Ignition relay goes into the front and up to the ignition  2 = Fuel Pump Relay <1M> (R-27) 37 = ING Relay <1M> I started from the pump using this reference Which the way I read it (referencing Nissan wiring color codes) is: Pin Wire Color Function 1 B/P (Black/Pink) Ground 2 L/W (Blue/White)        ECU Trigger 3 SB (Sky Blue) Fuel Pump 5 L/B (Blue/Black) 12V Constant Tested SB to SB on Fuel Pump for continuity - confirmed Tested negative on Fuel Pump to 12V battery and L/B - confirmed 12V Pulled the relay putting 12V between Pin 1 & 2 and testing continuity on Pin 3 & 4 - confirmed relay   So that has me looking at this part of the circuit to understand whats happening here...and im still confused. From best I can tell; the disconnect is back to my previous diagram; between Ignition Relay and Fuel Pump Relay...which yet again; afaik is where the immobiliser should.    Thats what I was trying to explain to GTSboy; im not trying to fix it myself; yet I seem to have to get a Masters in Electrical Engineering (while im busy doing my actual job of DevOps & Cloud Engineering) somehow.  I just wanted more expert opinions; or more so that what I tested is correct and proves it to something around that area; to go back to the alarm tech (for a 3rd time) that he needs to fix it. He keeps telling me its not the alarm. He lives on the complete other side of the city so i understand not wanting to make a trip but as I said before if its the alarm it should be up to him to fix it. But he's adament its not; even though I pointed out the FP was immobilised through the original alarm. To my mind; it seems that the ECU is sending the signal; but the ignition is not getting 12V down the line.
    • Maybe also really stiffly sprung track cars. Get the inside wheel up in a corner and all the fun stops. Also me sometimes (rarely) when I have to stand on the brake to convince the diff to drive the wheel that is still on the ground when I'm trying to diagonally get over severe driveway entrance, etc.
    • I feel like I'm missing something. You had an authorised installer come out and install a new alarm. Post install the car doesn't start, and you aren't getting the installer back to fix what they did wrong?
    • So either way it is gearbox out and look what is wrong?  I know about the input shaft bearing. Even before swap/new clutch the it sounded exactly like this: So is that inout shaft bearing or the other was installed backwards?  And can some please tell me the part number for that input shaft bearing? The gearbox is small box from R34 N/A and number is FS5W71C. Thank you
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
