hence why i said if it was a factory option for that particular vehicle, the furthest that would stretch would be nismo right?
Nismo parts aren't factory option though, They're aftermarket. Only time they'd be factory options would be for one of the Nismo released models, 400R, ZTune etc.
Not modifying an N1 kinda defeats the entire purpose it was built for in the first place. They're for race car homologation, it's supposed to be a race car. It's supposed to be a base to add on and change as your team sees fit to make it faster
Yeh, maybe if you were buying it new from factory as a base, you wouldn't be buying it as a base for mods 15 years down the track.
And I'm sure you understood what I meant by factory options. I thought nismo may have been a factory option, If not, then no mods :)
Nissan Motorsport International...
It's Nissan's Racing Division making Street Performance to GT Cars.
I would have a feeling Nissan would offer Nismo parts from dealer...
If not, you would have to take it to the Nismo Factories.
thats what I thought.. lol
collectors item i think...
if you bought it, you wouldnt be modifying it...
which is gay.... GTR's are for driving, not hardparking
wouldnt even tune it, why have some random tuner touch it.
only bits i would be putting on, is if they were a factory option for that particular car, like you said.. nismo..
i'd trust a tune from trent in australian weather / humidity / specific fuel etc over a factory nismo tune any day...
hardly some random
Just another 33 if you ask me
this
hardly some random
this
You would trust Trent, as a lot do, but other people may not and would consider him 'some random' not that I do..
yeah, but if it wasn't trent i could find another place that I would trust.
things age over 20 years too... not to mention that the jap tunes are different fuel...
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
