Stock coils are amazing....
15 year old Stock coils are not.
I gots no Wideband.
I went for the Walbro after going through 2 x Bosch 040's that kept dying after 6 months a diiiiirty tank of fuel, There's filter mesh on them but nothing like the sock of the Walbro.
Swapped the tank out for a clean one that a mate had, and no problems since.... Until now...
Major difference with this tune is that the intake cam was retarded 1 tooth, now fixed and I have a hell of a lot more midrange power/torque... so maybe the midrange is sucking more fuel out so it's running out of pressure after a few gear's worth of freight train goodness. :(
Obviously stock FPR... Anyone got a fuel pump I can borrow to test before Saturday? Otherwise I'll need to order one and get it delivered super quick.
Anyone know much bout Anatolian shepherds....looking at you nickolakis
Nah, we only have Sarplaninac
Actually our bitch is in season and we trying to get her in pup, so if you want one if she does let me know
Best dogs to the people they grow up with and awesome guard dogs
These are males though
http://www.youtube.com/watch?v=YhdXFZ-y7Ms
fkn huntsman's have a hard on for car panels
this, every.... farking.... time
Lol if Simon had a Neo he can try my coilpacks :P
Neo coilpacks/loom will work with S2 and vice versa, the Neo coilpacks bolt up to the S2 25 with only one bolt though cus they're different in that regard.
holy jeebize id love one but i dont think i could handle a bear haha
Dog or bear?
Fark I might be fuel actually.... It's not the same kind of power drop that I experienced when my stock coils died...
Fuel pump is an in tank Walbro.... I think its a 255L pump
AFR's on the tune looked alright, I'll upload a pic of the AFR graph when I get home.
Yeah AFR's are fine on boost....pretty flat between 11.2 and 11.8 from 3750-7200
Not sure if a single pull on the dyno would be enough to drain that much pressure though? Though, I guess it is in 4th so goes for longer :/
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
