no, he already beats his brother or atleast until mid third gear lol.. lol he has an FP green turbo on the evo, his brother is at 350kw or something and daniels at 223kw i think.. its quite amusing watching daniels car just chase things, its fkn lightning quick. after i drove his evo, its why i bought one
doesnt even need cams, more boost and he will be at around 300kw, i dont know what he's waiting for!
anyone got an old 4 channel amp laying around for cheap, or free.. lol i want to use something cheap to see whether I like my idea of the ipad thing, before i get better amps etc.
I have one that kinda works, you may be able to repair it. It's on the way out so I replaced it yesterday, picked up a brand new mb quart dsc480 for $120
whats wrong with it??
from where?
i may... i'll have a look
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
