whats wrong with it??
from where?
Speakers go crackly intermittently, I've tested it with another amp so it's not the speakers that are stuffed, amp may need some connections soldered or something
Got it from jb
no, he already beats his brother or atleast until mid third gear lol.. lol he has an FP green turbo on the evo, his brother is at 350kw or something and daniels at 223kw i think.. its quite amusing watching daniels car just chase things, its fkn lightning quick. after i drove his evo, its why i bought one
doesnt even need cams, more boost and he will be at around 300kw, i dont know what he's waiting for!
How much boost is he running now?
300kw at at the wheels in an evo is no easy feat.
There were a few around my area with big turbos and 2.4 strokers, cams etc makin around 320ish kw at the wheels.
Only running 19psi witch is very low in the evo world..... Cams, boost should place me in the HIGH!!!! 200kw...... I have all the supporting mods so why the bloody hell not... And I'm getting transfered to a closer store for work aprox 2km away from home so.......MEH
You got narre? Awesome
I'm very farmiliar with the evo world, I know them pretty well, that is low boost you're running. Nah all good man, hope you achieve your goals. I'd love to see the final results, post them up here when you get it all done.
Isn't 17-18PSI stock? (Either this or 15-16?) Or is it different for 6's?
Didn't know you had an FP Green... how is that tur-bro going? (Assuming your car is daily?)
Car sounds fun regardless!
Lol nah when I tell some ppl tht I'm running a low 19psi they almost do backflips "omg my 180 is only running 10psi and I thought I was running high boost" lol lol lol
Haha yeah I know, it can be a shock to some people.
sup motherf**kers.
how many turbros do i need to make 721 kws
has to be 721. not 720 or 722.
If you don't mind lag, use your mother.
If resposne is required, your sister and milk her a lot...
    • I will rebutt this and the preceding point from Dose....but without doing any calcs to demonstrate anything and without knowing that I am right or wrong. But... The flow capacity of a fluid transfer system is not limited by the smallest orifice or section of conduit in that system, unless it is drastically smaller than the rest of the system. OK, I use the word drastically perhaps with too much emphasis, but let's drill down on what I really mean. The flow capacity of the system is the result of the sum of the restrictions of the entire system. So, to make an extreme example, if you have a network with 3" pipe everywhere (and let's say a total length of only a few metres) and that 12mm ID restriction of the oil filter connection being the obvious restriction, then for any given amount of pressure available, the vast majority of all the pressure drop in the system is going to occur in the 12mm restriction. But.... increase the length of the 3" pipeline to, say 1000m, and suddenly the pipe pressure loss will likely add up to either be in the same order of magnitude, possibly even exceeding that of the 12mm restriction. Now the 12mm restriction starts to matter less. Translate this to the actual engine, actual oil cooler hose sizing, etc etc, and perhaps: The pressure loss caused by flowing through the narrow section (being the 12mm oil filter port, and perhaps any internal engine oil flow pathways associated with it) is a certain number. The pressure loss through, say, -12 hoses out to the cooler and back is negligible, but The pressure loss through -10 hoses out to the cooler, at the exact same length as the above, starts to become a decent fraction of the loss through the 12mm stuff at the filter port. Maybe even it starts to exceed it. I could actually do these calcs if I knew 1) how much oil was actually flowing in the line, 2) gave enough of a f**k to do things that I hate doing for work, voluntarily for a hypothetical discussion. Anyway - I reiterate. It's not the narrowest port that necessarily determines how much it can all flow. It is the sum. A long enough length of seemingly fat enough pipe can still cause more loss than a semmingly dominant small bore restriction.
    • To pick up what Dose is putting down. Not a lot of point running a huge hose if the motor is still restricted to the smaller size... It's only capable of flowing so much at that point...   *Waits for GTSBoy to come in and bring in the technicalities of length of pipe, and additional restriction from wall friction etc etc*
    • Hooley Dooley these things have some history! If i sell them they will need a certificate of providence to prove they have been in the hands of verified RB20 royalty! They have been stored in a plastic tub, away from sunlight and moisture. They are in mint condition. And they will stay that way, as i have sprung the money for a set of shockworks coilovers. I'm just working on getting them in at the moment, after rebushing the rear of the car, and while the subframe was out i welded in the GKtech reinforcement bracing as well.  They will get a workout at Ararat King of The Hill in November. I ran 48s on the short course there a few months ago, and i am hoping with new bushes and shocks in the rear i can launch a bit harder. There was a fair bit of axle tramp when i tried too hard off the line. a few of the corners had dips mid way which also made the car feel a bit unsettled, hopefully this will help there too.
    • Food for thought, the stock oil filter thread is a 3/4-16 UNF, which has an ID of about 10 to 12mm (according to ChatGPT lol). Now compare than to an 10AN, which has an ID of about 14mm (Raceworks is 14.2mm, Speed flow is 14.27mm).
    • Yep, totally get that. However hooking in for Generator back up is only a few hundred bucks for the wiring. You could put a couple of those in (for different circuits explicitly) and run a couple of baby generators. Bonus, you can balance them across different circuits, and now have backups in your backup. I'm looking at buying places that won't even have water etc, and I don't mind the idea of getting off the electric grid either, even with everything you've said. This country already has enough power outages that even the mains grid isn't that reliable anymore. I do agree though on spending a bit more to get better gear, and to add some extra redundancy in to the system too.
