Just bought 25 of the delightful bastards!
Big w I got my stash. Coles will have some eventually.
That's shit cray.
Just had a look in my local Safeway and they dot have any so ill try Coles later. How much these bad boys cost?
In what store can I find the fabled chocolate esquilax?
just covering all the bases though, because changi village nasi lemak is no big deal tbh.
hence me saying "aparently" (or something to that effect)
also, i'll take anthony bourdains word on food over yours ANY DAY :P
$1 a pop. Massively undervalued.
Try big w I guess already half sold out since yesterday :/
Farrrrrk. Going to raid Chaddy tonight. By the way man been meaning to ask any idea what fuel pump you were running when I bought the 33 off you? Went to replace it and the mechanic said the one that was in there was flowing twice what a gss342 does.
I didn't know it was you that bought my car! How's it treating ya?
It was replaced @ jap warehouse forget the name there's two main brands whalbro and one other common one I believe it was the other one
Did it die? Cos would only be like 18 months old 2 years max
Edited by alr33x
Haha yeah, been keeping a low profile lol! It's running great, hopefully get down to some track days this year and some SAU meets.
Nah hasn't died at all, was going to replace it thinking it was running stock pump, but turns out that it wasn't haha :D
Yeh I would go too stupid hamish but agree if I got wheels they'd have to have an oem look with better good offset and not crazy low like the 33 was more a clean look seen a few look ok
Like this guys rolling shots look baller
http://www.audizine.com/forum/showthread.php/461266-Mop-s-Build-Thread/page3
http://www.audizine....ld-Thread/page3
That looks real nice!
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
