Anyone able to fill me in on what pod filters you can buy from Supercheap & Autobarn? FRsport has like $60 postage :( and i dont want multiple items.
Usually Drift, K&N, and some can get in other brands I believe such as HKS but it'd be on order.
Nobody wants it :(, should probably just throw it out.
Have this one its way to me which I think is a K&N filter, only bought it for the Tomei adapter thoughdon't want filter & s15 afm.
http://page11.auctions.yahoo.co.jp/jp/auction/n118325010
Did some research, seems everyone is referencing Autosalon comparison of filters in regards to 3A. Found some scans of it if you want to have a read.
http://www.aussiemagna.com/forums/showthread.php?t=73847
Yeh I would go too stupid hamish but agree if I got wheels they'd have to have an oem look with better good offset and not crazy low like the 33 was more a clean look seen a few look ok
Like this guys rolling shots look baller
http://www.audizine....ld-Thread/page3
Cmon Alex
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
